Lenovo Z70-80 Optical Drive Replacement
  1. Lenovo Z70-80 Optical Drive Replacement, Battery: step 1, image 1 of 2 Lenovo Z70-80 Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Use your fingers two push both latches away from each other to release the battery.
    • Pull the battery out.
  2. Lenovo Z70-80 Optical Drive Replacement, Back Panel: step 2, image 1 of 3 Lenovo Z70-80 Optical Drive Replacement, Back Panel: step 2, image 2 of 3 Lenovo Z70-80 Optical Drive Replacement, Back Panel: step 2, image 3 of 3
    • Remove the two Phillips #0 screws from the bottom panel.
    • Slide the panel down slightly, and then lift to pull it off.
  3. Lenovo Z70-80 Optical Drive Replacement, Optical Drive: step 3, image 1 of 3 Lenovo Z70-80 Optical Drive Replacement, Optical Drive: step 3, image 2 of 3 Lenovo Z70-80 Optical Drive Replacement, Optical Drive: step 3, image 3 of 3
    • Remove the single 3mm Phillips #0 screw from the optical drive.
    • Pull the optical drive out of the side.
Eduardo Delgado
412 Reputation
4 Guides authored
Gateway, Team S1-G4, Johnson Spring 2018 Member of Gateway, Team S1-G4, Johnson Spring 2018
GCC-JOHNSON-S18S1G4
2 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 899
