Lens Cover Replacement
  1. Lens Cover Replacement, Lens Cover: step 1, image 1 of 1
    • Unscrew the two small screws on the black side panel of the camera using a PH00 screwdriver. Remove the part.
  2. Lens Cover Replacement: step 2, image 1 of 1
    • You will need to remove the front panel in order to access the lens. Lift the latches on the side of the front panel to remove it entirely, pulling gently in an upward motion.
  3. Lens Cover Replacement: step 3, image 1 of 1
    • Locate silver lens covering.
  4. Lens Cover Replacement: step 4, image 1 of 1
    • Use your PH00 screwdriver to unscrew the lens cover.
    • Remove the screw.
    • Remove the lens cover.
One Comment
I found that additional steps are needed between steps 2 and 3 to remove 5 additional screws before the front panel can be removed.
Was my Olympus 850 SW different from the one repaired in that tutorial?
I took pictures that I could insert in the tutorial, but did not find how to do it.
Michel
Michel Martin - Reply
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 22
All Time: 1,108
