Lens Replacement
  1. Lens Replacement, Lens: step 1, image 1 of 3 Lens Replacement, Lens: step 1, image 2 of 3 Lens Replacement, Lens: step 1, image 3 of 3
    • Step 1. Remove: Remove the indicated screws from the camera.
  2. Lens Replacement: step 2, image 1 of 3 Lens Replacement: step 2, image 2 of 3 Lens Replacement: step 2, image 3 of 3
    • Step 2. Remove all the screws: Keep all the screws and disconnect the cables carefully.
    • Step 3. Lift: After removing all the cables, lift up and flip over the PCB.
  3. Lens Replacement: step 3, image 1 of 2 Lens Replacement: step 3, image 2 of 2
    • Step 4. Remove: Remove marked screws on top and around the lent.
    • **Remove all the parts, be aware that there are a lot of screws and keep count them a long the way of the dissambley **
  4. Lens Replacement: step 4, image 1 of 2 Lens Replacement: step 4, image 2 of 2
    • Step 5. Carefully remove as much of the glue as possible before proceeding to the next step.
    • Step 6. Remove the marked focus spacers.
    • Place a bead of silicone adhesive on each side of the ir filter to fix it in position and allow to cure.
Marina Bayardo
251 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 38
All Time: 1,547
