Les Paul Wireless Guitar Battery Pack Replacement
Chris
Chris and 5 other contributors
Last updated on January 25, 2024
No estimate
Easy
Introduction
Go to step 1
This guide will show how to replace the guitar's battery pack. The battery pack supplies power to the controller and houses the two AA batteries required for the controller.
Tools
  1. Les Paul Wireless Guitar Battery Pack Replacement, Les Paul Wireless Guitar Body Teardown: step 1, image 1 of 1
    • Remove batteries
  2. Les Paul Wireless Guitar Battery Pack Replacement: step 2, image 1 of 2 Les Paul Wireless Guitar Battery Pack Replacement: step 2, image 2 of 2
    • Remove void warranty sticker
    • The sticker is covering a torx screw
  3. Les Paul Wireless Guitar Battery Pack Replacement: step 3, image 1 of 3 Les Paul Wireless Guitar Battery Pack Replacement: step 3, image 2 of 3 Les Paul Wireless Guitar Battery Pack Replacement: step 3, image 3 of 3
    • Unscrew the 11 screws securing the back of the body using a T10 Torx screwdriver. Each screw is 1 cm long.
    • Push level, this will detach the back of the guitar from the front.
    • Carefully remove the back of the body
    • The battery pack cord is attached to both sides of the guitar, be careful not to tear it apart.
    • The neck connector may be stuck to the back so be sure to detach it before fully pulling
  4. Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: step 4, image 1 of 2 Les Paul Wireless Guitar Battery Pack Replacement, Battery Pack: step 4, image 2 of 2
    • Gently move the capacitor around until it breaks off
  5. Les Paul Wireless Guitar Battery Pack Replacement: step 5, image 1 of 1
    • Solder on the new capacitor.
3 other people completed this guide.
Chris
905 Reputation
6 Guides authored
3 Comments
What cap is needed?
Martin Samuelsson - Reply
Mine is: 2200uF 10V
Thijs van Ulden -
Necesito cambiar todo el habitaculo de las pilas por oxido, cual es la pieza exacta que necesito?
Jose Miguel - Reply
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 87
All Time: 13,428
