Les Paul Wireless Guitar Peripheral Fret Buttons Replacement
  1. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement, Fret Buttons: step 1, image 1 of 1
    • Pull the Lock on the back of the body to detach the neck from the body.
  2. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: step 2, image 1 of 2 Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: step 2, image 2 of 2
    • Remove the 10 screws (each are 1 cm long) on the back of the neck using a T-10 Torx security screwdriver.
    • Remove the back of the neck.
  3. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: step 3, image 1 of 2 Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: step 3, image 2 of 2
    • Unscrew the two screws on the fret PCB using a PH1 Phillips head screwdriver. Each screw is 0.8 cm.
    • Remove the fret PCB
    • The fret PCB is in very tight. Be careful not to break it.
    • The connector from the neck to the body can easily slide out of place. Make sure it is in position before closing the neck
  4. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: step 4, image 1 of 1
    • Remove the blue fret button pad.
    • This pad should not be attached in any way
  5. Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: step 5, image 1 of 2 Les Paul Wireless Guitar Peripheral Fret Buttons Replacement: step 5, image 2 of 2
    • The fret buttons should now easily slide out.
6 other people completed this guide.
Chris
881 Reputation
6 Guides authored
One Comment
There are actually 12 screws in Step2. Just in case anyone is confused by that; starting from the right side we have a pair lined horizontally, pair lined vertically, pair lined horizontally....
The two that are vertically between the other two pairs, are not marked in the photo.
Vynneve - Reply
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 103
All Time: 20,639
