Levoit Core 300-RAC Control Board Replacement
  1. Levoit Core 300-RAC Control Board Replacement, Control Board: step 1, image 1 of 3 Levoit Core 300-RAC Control Board Replacement, Control Board: step 1, image 2 of 3 Levoit Core 300-RAC Control Board Replacement, Control Board: step 1, image 3 of 3
    • Make sure the device is turned off and unplugged before disassembling it.
    • Insert the Jimmy between the gray grille cover and the top of the device.
    • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
    • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
    • Remove the grille cover gently as it is connected by a ribbon cable.
    • Be careful not to put too much strain on the ribbon cable as it may break.
  2. Levoit Core 300-RAC Control Board Replacement: step 2, image 1 of 3 Levoit Core 300-RAC Control Board Replacement: step 2, image 2 of 3 Levoit Core 300-RAC Control Board Replacement: step 2, image 3 of 3
    • Squeeze the tab on the connector to release the bundled cable from the control board.
    • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
  3. Levoit Core 300-RAC Control Board Replacement: step 3, image 1 of 2 Levoit Core 300-RAC Control Board Replacement: step 3, image 2 of 2
    • Gently bend the gray plastic cover to release the control board.
    • There are several hard tabs holding the control board in place.
  4. Levoit Core 300-RAC Control Board Replacement: step 4, image 1 of 3 Levoit Core 300-RAC Control Board Replacement: step 4, image 2 of 3 Levoit Core 300-RAC Control Board Replacement: step 4, image 3 of 3
    • Lift the control board from the gray plastic cover.
    • Take note of the orientations of the buttons, as that will help during reassembly.
Mustafa
259 Reputation
1 Guide authored
UMass Dartmouth, Team 1-6, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-6, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G6
5 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 68
All Time: 1,320
