Levoit LV-H132 LED Replacement
  1. Levoit LV-H132 LED Replacement, LED: step 1, image 1 of 2 Levoit LV-H132 LED Replacement, LED: step 1, image 2 of 2
    • Pry off the plastic top using a metal spudger.
  2. Levoit LV-H132 LED Replacement: step 2, image 1 of 2 Levoit LV-H132 LED Replacement: step 2, image 2 of 2
    • Remove the three 1.2 mm screws with a Phillips #1 screwdriver.
  3. Levoit LV-H132 LED Replacement: step 3, image 1 of 2 Levoit LV-H132 LED Replacement: step 3, image 2 of 2
    • Disconnect the top half from the bottom.
  4. Levoit LV-H132 LED Replacement: step 4, image 1 of 3 Levoit LV-H132 LED Replacement: step 4, image 2 of 3 Levoit LV-H132 LED Replacement: step 4, image 3 of 3
    • Disconnect the circuit board cable.
  5. Levoit LV-H132 LED Replacement: step 5, image 1 of 2 Levoit LV-H132 LED Replacement: step 5, image 2 of 2
    • Remove the two 5 mm screws with a Phillips #1 screwdriver.
  6. Levoit LV-H132 LED Replacement: step 6, image 1 of 1
    • Desolder the joints holding the faulty LED and switch to the PCB.
    • Slide the faulty LED out and replace it with the functional one.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 302
