Lexmark Intuition S505 Ink Cartridges Replacement
  1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: step 1, image 1 of 2 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: step 1, image 2 of 2
    • Lift the scanning unit, exposing the print head.
  2. Lexmark Intuition S505 Ink Cartridges Replacement: step 2, image 1 of 1
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
  3. Lexmark Intuition S505 Ink Cartridges Replacement: step 3, image 1 of 1
    • Lift the frame to expose the ink cartridges.
  4. Lexmark Intuition S505 Ink Cartridges Replacement: step 4, image 1 of 1
    • Push the button located above the designated ink cartridge until it pops out.
  5. Lexmark Intuition S505 Ink Cartridges Replacement: step 5, image 1 of 1
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
  6. Lexmark Intuition S505 Ink Cartridges Replacement: step 6, image 1 of 2 Lexmark Intuition S505 Ink Cartridges Replacement: step 6, image 2 of 2
    • Close the scanner unit.
Once your ink cartridges are in place, your printer should now print high-quality documents.
2 other people completed this guide.
Omar
111 Reputation
2 Guides authored
Cal Poly, Team 18-38, Regan Winter 2013 Member of Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Members
8 Guides authored
One Comment
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 3,270
