Lexmark MX611de Maintenance Kit Replacement
  1. Lexmark MX611de Maintenance Kit Replacement, Right Cover Removal: step 1, image 1 of 2 Lexmark MX611de Maintenance Kit Replacement, Right Cover Removal: step 1, image 2 of 2
    • Remove the paper tray
    • Remove the screw securing the right cover to the front of the printer frame.
    • Open the memory access cover that is attached to the right cover
    • Remove the two screws securing the right cover to the RIP shield.
    • Slightly lift the printer, slide the right cover forward, and pull it out and away from the printer
    • Remove the screw securing the left cover to the front of the printer frame.
    • Release the Two tabs on the bottom of the cover.
    • Pull the cover forward, and remove it from the printer.
    • Open rear door.
    • Pull the exit door upward to release the hinges, and remove.
    • Remove the two screws securing the rear cover.
    • Remove the cover.
    • Remove the three screws from the Left Mounting Bracket
    • Two different ways to the next step, dependent on experience and/or confidence.
    • Move the the Mounting Bracket over while extending the Stapler Cable out of the way, The Stapler cable does not have to disconnected.
    • Remove the Stapler Cable and Mounting bracket from the printer frame while feeding the cable through the redrive unit and printer frame.
    • Using a pair of pliers, squeeze the nylon mounts to dislodge the stapler connector, and remove the cable.
    • Remove the three screws from the Right mounting bracket.
    • Remove the Two screws, and then disconnect the reverse solenoid.
    • Do not disconnect the reverse solenoid cable from the controller board.
    • Remove the Six screws securing the redrive assembly.
    • Disconnect the cable JEXIT1 from the controller board.
    • Disconnect the Two cables.
    • Remove the Two screws securing the fuser.
alarson118
553 Reputation
3 Guides authored
Tech-zone Member of Tech-zone
Business
2 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 39
All Time: 5,634
