Lexmark T650 Fuser Roller Replacement
    • A damaged pressure roller leads to paper jams.
    • A damaged non-stick coating on the heated roller causes dark marks and double images. Toner that sticks to the non stick coating on the heated roller makes an after-image or marks 94mm (3.7 inches) below the original dark print.
  1. Lexmark T650 Fuser Roller Replacement, Remove front cover: step 2, image 1 of 1
    • Remove these two 6mm Philips #2 screws then remove the front cover
  2. Lexmark T650 Fuser Roller Replacement, Remove top cover: step 3, image 1 of 2 Lexmark T650 Fuser Roller Replacement, Remove top cover: step 3, image 2 of 2
    • Remove these two 6mm #2 screws from the two ends of the heating element and carefully withdraw the glass heating element.
    • The glass heating element is shown in the second picture.
    • Remove these two 6mm #2 screws attaching the top cover.
    • Remove this screw attaching the red power cable.
    • Unplug the pair of yellow wires and unhook them from the hooks tucking them in place.
    • The top cover can now be removed.
  3. Lexmark T650 Fuser Roller Replacement, Release the springs: step 4, image 1 of 2 Lexmark T650 Fuser Roller Replacement, Release the springs: step 4, image 2 of 2
    • Insert a wedge under each of the two spring support arms to lift the two springs.
    • The wedges should remain in place while the fuser unit is being stored. Otherwise the pressure from top roller will make a permanent indentation in the soft pressure roller.
    • The second picture shows a suitable wedge. This example was made from a toothbrush handle.
  4. Lexmark T650 Fuser Roller Replacement, Remove paper guide: step 5, image 1 of 2 Lexmark T650 Fuser Roller Replacement, Remove paper guide: step 5, image 2 of 2
    • gently bend this paper guide to remove it.
  5. Lexmark T650 Fuser Roller Replacement, Remove top roller: step 6, image 1 of 3 Lexmark T650 Fuser Roller Replacement, Remove top roller: step 6, image 2 of 3 Lexmark T650 Fuser Roller Replacement, Remove top roller: step 6, image 3 of 3
    • Use circlip pliers to remove the circlip attaching the cogwheel to the top roller.
    • Slide this metal catch upwards to release the bearing from its holder. Remove the bearing.
    • The top roller can now be removed.
    • The red pressure roller is now visible with its bearings resting in the holder at each end.
  6. Lexmark T650 Fuser Roller Replacement, Remove the pressure roller: step 7, image 1 of 2 Lexmark T650 Fuser Roller Replacement, Remove the pressure roller: step 7, image 2 of 2
    • The pressure roller can now be lifted out.
3 other people completed this guide.
David42
1,508 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 39
All Time: 1,770
