LifePrint 2x3 Battery Replacement
  1. LifePrint 2x3 Battery Replacement, Battery: step 1, image 1 of 2 LifePrint 2x3 Battery Replacement, Battery: step 1, image 2 of 2
    • Orient the LifePrint 2x3 so that the top of the device is facing upwards. Slide the top cover toward the far side of the device and remove it.
  2. LifePrint 2x3 Battery Replacement: step 2, image 1 of 3 LifePrint 2x3 Battery Replacement: step 2, image 2 of 3 LifePrint 2x3 Battery Replacement: step 2, image 3 of 3
    • Remove the six 5.24 mm screws located around the edges of the device using a Phillips #00 Screwdriver.
  3. LifePrint 2x3 Battery Replacement: step 3, image 1 of 3 LifePrint 2x3 Battery Replacement: step 3, image 2 of 3 LifePrint 2x3 Battery Replacement: step 3, image 3 of 3
    • Flip the LifePrint 2x3 upside down. Using a plastic opening pick, separate the bottom cover from the device and remove it.
  4. LifePrint 2x3 Battery Replacement: step 4, image 1 of 3 LifePrint 2x3 Battery Replacement: step 4, image 2 of 3 LifePrint 2x3 Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    $3.99
    Buy
    • Using the angled tweezers grip the sides of the connector and slowly rock it side to side to remove. If the connector is not disconnecting, try using the spudger but be careful not to damage the motherboard.
    • Once disconnected, remove the old battery.
6 Guide Comments
Hi. Where can you buy the replacement battery? Thank you.
martin.thomas - Reply
Where can whe buy that battery?
lp1979 - Reply
Hi can I know where I can buy the battery?
Amelia Halliwell - Reply
bel article but where to buy the battery ?
What kind and characteristics of the battery ?
Baphi - Reply
I found it hard to buy the battery, you can buy 2 small Li ion batteries of 3.7V, and put them in series, that way you get a battery you can use
Is something homemade but it works. Reutilize the 5P with the NTC, and connect the NTC to ground if your 3V doesn't have one.
Btw original characteristics are
- 7.4V nominal
- 8.4V charge
- 500mAh
- 3.7Wh
https://es.aliexpress.com/item/100500537...
Burquillo Polamillo - Reply
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 54
All Time: 790
