Lifetime 4-Foot Adjustable Table Leg Replacement
  1. Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: step 1, image 1 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: step 1, image 2 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement, Leg: step 1, image 3 of 3
    • Use the 6 mm Flathead screwdriver to remove the four aluminum slotted screws located on the edges of the table.
    • Use a 5/32" Allen Wrench or 19 mm wrench to remove the two stainless 8-18 steel hex screws from the braces of the table.
  2. Lifetime 4-Foot Adjustable Table Leg Replacement: step 2, image 1 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement: step 2, image 2 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement: step 2, image 3 of 3
    • Clean any glue or adhesive from the braces and hinges before putting it into place.
    • It’s important to clear the screw holes of any material, so that the screws can fit without obstruction.
  3. Lifetime 4-Foot Adjustable Table Leg Replacement: step 3, image 1 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement: step 3, image 2 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement: step 3, image 3 of 3
    • Align the screw holes of the braces with the new leg by inserting it into the frame.
    • While aligning, make sure the new leg fits into the frame slots.
  4. Lifetime 4-Foot Adjustable Table Leg Replacement: step 4, image 1 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement: step 4, image 2 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement: step 4, image 3 of 3
    • Place the two stainless steel hex screws inside of the screw holes located on the leg, and secure each screw with your Allen key or wrench.
  5. Lifetime 4-Foot Adjustable Table Leg Replacement: step 5, image 1 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement: step 5, image 2 of 3 Lifetime 4-Foot Adjustable Table Leg Replacement: step 5, image 3 of 3
    • Screw the four slotted screws back into the frame using a 6 mm flathead screwdriver. Ensure that the entire side where the new leg is being inserted is securely connected to the table once again.
  6. Lifetime 4-Foot Adjustable Table Leg Replacement: step 6, image 1 of 1
    • Test out the table by unfolding it, and setting it up in a standing position.
    • If the leg is not aligned properly, has loose screws, or missing some screws, make the proper adjustments before using it.
Aphason Aberham
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 78
All Time: 1,415
