Lightahead DV328 Battery Replacement
  1. Lightahead DV328 Battery Replacement, Battery: step 1, image 1 of 1
    • The first step will require you to take off the cover where the battery will be located under
  2. Lightahead DV328 Battery Replacement: step 2, image 1 of 1
    • You will then see the battery and a strap coming out from underneath it
  3. Lightahead DV328 Battery Replacement: step 3, image 1 of 2 Lightahead DV328 Battery Replacement: step 3, image 2 of 2
    • Pull this strap upward and the battery will pop right out
    • You will then be able to replace the battery as needed
Alexandra McMurray
355 Reputation
3 Guides authored
USF Tampa, Team 10-2, Remmell Spring 2016 Member of USF Tampa, Team 10-2, Remmell Spring 2016
USFT-REMMELL-S16S10G2
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 196
