Lightahead DV328 Strap Replacement
  1. Lightahead DV328 Strap Replacement, Strap: step 1, image 1 of 3 Lightahead DV328 Strap Replacement, Strap: step 1, image 2 of 3 Lightahead DV328 Strap Replacement, Strap: step 1, image 3 of 3
    • To access the area underneath the camcorder, remove the two pieces covering the screws with a plastic spudger.
    • Remove the two Phillips #2 screws.
    • Gently pull up the cover.
  2. Lightahead DV328 Strap Replacement: step 2, image 1 of 3 Lightahead DV328 Strap Replacement: step 2, image 2 of 3 Lightahead DV328 Strap Replacement: step 2, image 3 of 3
    • Pull off the lens.
    • Be careful not to pull the cover too far up, otherwise it will snap in half.
    • Inside the device the motherboard and a screw will be visible.
    • Remove the pictured Philips #0 screw to release the strap.
Alexandra McMurray
355 Reputation
3 Guides authored
USF Tampa, Team 10-2, Remmell Spring 2016 Member of USF Tampa, Team 10-2, Remmell Spring 2016
USFT-REMMELL-S16S10G2
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 195
