Linksys EA6900 Router Reset Button Replacement
  1. Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: step 1, image 1 of 3 Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: step 1, image 2 of 3 Linksys EA6900 Router Reset Button Replacement, Linksys EA6900 Disassembly: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Linksys EA6900 Router Reset Button Replacement: step 2, image 1 of 1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Linksys EA6900 Router Reset Button Replacement: step 3, image 1 of 1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Linksys EA6900 Router Reset Button Replacement: step 4, image 1 of 3 Linksys EA6900 Router Reset Button Replacement: step 4, image 2 of 3 Linksys EA6900 Router Reset Button Replacement: step 4, image 3 of 3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Linksys EA6900 Router Reset Button Replacement, Router Reset Button: step 5, image 1 of 2 Linksys EA6900 Router Reset Button Replacement, Router Reset Button: step 5, image 2 of 2
    • Make sure to correctly identify the red router reset button.
    • Locate the four solder points on the other side of the motherboard.
  6. Linksys EA6900 Router Reset Button Replacement: step 6, image 1 of 2 Linksys EA6900 Router Reset Button Replacement: step 6, image 2 of 2
    • Be careful when working with the hot soldering iron! Make sure the router motherboard is safely resting on a level and sturdy surface.
    • Carefully apply the soldering iron to the four solders. Avoid touching the motherboard with the soldering iron, this could damage the circuits.
    • Use a spudger to gently pry and remove the reset button once the solder has melted.
4 other people completed this guide.
Rick Hsu
355 Reputation
1 Guide authored
USF Tampa, Team 11-1, Blackwell Fall 2016 Member of USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 32
All Time: 1,790
