Linksys EA9200 USB Port Replacement
  1. Linksys EA9200 USB Port Replacement, Linksys EA9200 Disassembly: step 1, image 1 of 2 Linksys EA9200 USB Port Replacement, Linksys EA9200 Disassembly: step 1, image 2 of 2
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Linksys EA9200 USB Port Replacement: step 2, image 1 of 2 Linksys EA9200 USB Port Replacement: step 2, image 2 of 2
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Linksys EA9200 USB Port Replacement: step 3, image 1 of 3 Linksys EA9200 USB Port Replacement: step 3, image 2 of 3 Linksys EA9200 USB Port Replacement: step 3, image 3 of 3
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  4. Linksys EA9200 USB Port Replacement: step 4, image 1 of 3 Linksys EA9200 USB Port Replacement: step 4, image 2 of 3 Linksys EA9200 USB Port Replacement: step 4, image 3 of 3
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  5. Linksys EA9200 USB Port Replacement: step 5, image 1 of 3 Linksys EA9200 USB Port Replacement: step 5, image 2 of 3 Linksys EA9200 USB Port Replacement: step 5, image 3 of 3
    • Lift the board and pull down, away from the antennas.
  6. Linksys EA9200 USB Port Replacement, USB Port: step 6, image 1 of 2 Linksys EA9200 USB Port Replacement, USB Port: step 6, image 2 of 2
    • Desolder the 6 pin points fully.
    • How To Solder and Desolder Connections is iFixit's official guide on how to use a soldering iron.
    • You will need a soldering iron that is capable of reaching temperatures greater than 300 degrees Fahrenheit.
    • Temperature of the component will be very hot when desoldered, take precaution when handling.
Shane Davis
374 Reputation
3 Guides authored
USF Tampa, Team 9-1, Lacy Fall 2016 Member of USF Tampa, Team 9-1, Lacy Fall 2016
USFT-LACY-F16S9G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 8
All Time: 338
