Linksys WAP54g LED Lights Replacement
  1. Linksys WAP54g LED Lights Replacement, Top Casing: step 1, image 1 of 1
    • Power down and unplug the device.
  2. Linksys WAP54g LED Lights Replacement: step 2, image 1 of 1
  3. Linksys WAP54g LED Lights Replacement: step 3, image 1 of 1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g LED Lights Replacement: step 4, image 1 of 1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g LED Lights Replacement: step 5, image 1 of 1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g LED Lights Replacement: step 6, image 1 of 1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g LED Lights Replacement: step 7, image 1 of 2 Linksys WAP54g LED Lights Replacement: step 7, image 2 of 2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g LED Lights Replacement: step 8, image 1 of 2 Linksys WAP54g LED Lights Replacement: step 8, image 2 of 2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: step 9, image 1 of 2 Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: step 9, image 2 of 2
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
  10. Linksys WAP54g LED Lights Replacement, LED Lights: step 10, image 1 of 1
    • Using a soldering iron, desolder the LED lights from the bottom of the logic board.
    • For help with soldering or desoldering refer to ifixit's soldering guide: How To Solder and Desolder Connections
  11. Linksys WAP54g LED Lights Replacement: step 11, image 1 of 1
    • Place new LED lights through holes created by desoldering and removing old lights.
  12. Linksys WAP54g LED Lights Replacement: step 12, image 1 of 2 Linksys WAP54g LED Lights Replacement: step 12, image 2 of 2
    • Solder the lights onto the bottom of the board to solidify the connection and make electrical contact.
    • Follow the Installing the Casing guide in reverse to re-assemble your device.
Once the soldering is complete, the device should work and the LED lights should light up.
Derek Myers
288 Reputation
5 Guides authored
Cal Poly, Team 21-21, Maness Fall 2011 Member of Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 2,081
