Linksys WRT54G Motherboard Replacement
  1. Linksys WRT54G Motherboard Replacement, Antennas: step 1, image 1 of 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Motherboard Replacement: step 2, image 1 of 3 Linksys WRT54G Motherboard Replacement: step 2, image 2 of 3 Linksys WRT54G Motherboard Replacement: step 2, image 3 of 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Motherboard Replacement: step 3, image 1 of 3 Linksys WRT54G Motherboard Replacement: step 3, image 2 of 3 Linksys WRT54G Motherboard Replacement: step 3, image 3 of 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Motherboard Replacement, Casing: step 4, image 1 of 2 Linksys WRT54G Motherboard Replacement, Casing: step 4, image 2 of 2
    • Using a bit of force, remove the blue plastic case.
  5. Linksys WRT54G Motherboard Replacement, Motherboard: step 5, image 1 of 2 Linksys WRT54G Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
    • Pull the top piece upwards and away from the bottom to remove.
  6. Linksys WRT54G Motherboard Replacement: step 6, image 1 of 2 Linksys WRT54G Motherboard Replacement: step 6, image 2 of 2
    • Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
    • Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
  7. Linksys WRT54G Motherboard Replacement: step 7, image 1 of 1
    • Once screws have been removed, slide the motherboard in the direction of its LED lights.
    • Lift motherboard up and away from the black lower casing.
3 other people completed this guide.
Aaron Brown
163 Reputation
2 Guides authored
Cal Poly, Team 17-7, Regan Fall 2011 Member of Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 3,406
