LisaTerminal with Linux/UNIX(Mac)
  1. LisaTerminal with Linux/UNIX(Mac), On Linux: step 1, image 1 of 1
    • In Terminal type: sudo apt-get install screen
    • sudo screen /dev/ttyUSB0 9600
    • Press ⌃A ⇧ : (at the same time). Once you see a : prompt at the bottom of the screen type
    • exec ::: /sbin/agetty -L -n 9600 ttyUSB0 vt100
    • Press return a few times on the Lisa keyboard and the login prompt should appear.
  2. LisaTerminal with Linux/UNIX(Mac), On macOS: step 2, image 1 of 1
    • Type: ls /dev/cu.*
    • Copy the result that mentions USB
    • Then type the following replacing serial with the previous result: screen /dev/serial 9600
    • Press ⌃A ⇧:
    • When the : prompt appears type
    • exec ::: /usr/libexec/getty std.9600
    • Open LisaTerminal and set the settings to baud rate 9600 and set serial port to A.
    • Plug the serial cable into serial port A.
    • In MacWorks Plus and Macintosh System 6, the application Mac240 supports graphics and is generally fantastic for this type of connection.
    • Mac240 can be acquired from Macintosh Garden.
  3. LisaTerminal with Linux/UNIX(Mac), Uses: step 4, image 1 of 1
    • This was done so I could use mutt for email and w3m for web browsing
    • mpg123 is great for music if your connected computer has speakers.
Finish Line
LisaGuide
1,833 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 768
