Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement
  1. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Safety precautions: step 1, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Safety precautions: step 1, image 2 of 2
    • Before you begin, ensure that the engine is off and cool to the touch.
  2. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 2, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 2, image 2 of 2
    • Locate the gas cutoff valve and flip the switch to the left to shut it.
  3. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 3, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 3, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Remove the deflector cable: step 4, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Remove the deflector cable: step 4, image 2 of 2
    • Remove the cotter pin from the clevis.
  5. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 5, image 1 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 5, image 2 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 5, image 3 of 3
    • Remove the clevis pin.
  6. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 6, image 1 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 6, image 2 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 6, image 3 of 3
    • Slide the ball at the end of the cable through the round opening in the clevis.
    • Remove the clevis from the deflector cable.
  7. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 7, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 7, image 2 of 2
    • Slide the rubber boot off of the cable housing to the end of the cable.
  8. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 8, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 8, image 2 of 2
    • Use a 7/16 inch wrench to unscrew the nut securing the cable housing to the bracket.
  9. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 9, image 1 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 9, image 2 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 9, image 3 of 3
    • Slide the cable housing out from the deflector lever bracket.
  10. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Remove the master link: step 10, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Remove the master link: step 10, image 2 of 2
    • The next two steps will show you how to remove the master link on the deflector chain.
  11. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 11, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 11, image 2 of 2
    • Use a pair of pliers to unclip the master link.
    • Remove the master link retaining clip.
  12. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 12, image 1 of 1
    • Remove the outer plate.
  13. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 13, image 1 of 1
    • Remove the chain from the end of the deflector cable.
    • Repeat steps 11–13 for the upper master link if necessary.
    • During reassembly, follow steps 11-13 in reverse order to reinstall the master links.
  14. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 14, image 1 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 14, image 2 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 14, image 3 of 3
    • Squeeze the tabs on either side of the cable pusher with a pair of pliers and slide it through the bracket.
    • Remove the deflector cable.
  15. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Install the new deflector chain: step 15, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Install the new deflector chain: step 15, image 2 of 2
    • The following steps show how to install a new deflector chain.
    • Note the center link on the deflector chain.
    • Note the middle tooth of the pivot.
    • The deflector knob has been removed for illustrative purposes.
  16. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 16, image 1 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 16, image 2 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 16, image 3 of 3
    • Drop the middle link onto the middle tooth of the pivot.
  17. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement, Adjust the deflector cable: step 17, image 1 of 1
    • Lift the deflector so that it is horizontal.
    • Turn the deflector knob clockwise to lock the deflector horizontally in the wide-open position.
  18. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 18, image 1 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 18, image 2 of 3 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 18, image 3 of 3
    • Slide the cable housing back onto the deflector lever bracket.
  19. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 19, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 19, image 2 of 2
    • Slide the clevis back on to the deflector cable.
  20. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 20, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 20, image 2 of 2
    • Insert the clevis pin through the clevis and the deflector adjustment lever.
  21. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 21, image 1 of 1
    • Move the deflector lever into the open position.
  22. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 22, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 22, image 2 of 2
    • Use an open-ended wrench to tighten the 7/16 inch bolt until the cable is taught.
  23. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 23, image 1 of 1
    • Slightly loosen the deflector knob to allow the deflector to move freely.
  24. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 24, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 24, image 2 of 2
    • Use the lever to open and close the deflector to check that cable is properly adjusted.
    • If the deflector does not fully open, the cable needs to be tightened more:
    • Repeat step 17, then step 22 but give the nut an additional clockwise turn.
    • Repeat steps 23–24.
    • If the deflector does not fully close, the cable needs more slack:
    • Repeat step 17, then step 22 but give the nut an addition counterclockwise turn.
  25. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 25, image 1 of 1
    • Use an open-ended wrench to tighten the other 7/16 inch bolt on the cable housing until it is snug against the bracket.
  26. Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 26, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Deflector Chain and Cable Replacement: step 26, image 2 of 2
    • Slide the rubber boot back onto the end of the cable housing.
    • Install the cotter pin onto the clevis pin.
Finish Line
Sam Omiotek
75,409 Reputation
288 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 666
