Little Wonder GX270 Honda Maximum Output Blower Fan Replacement
  1. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Safety precautions: step 1, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Safety precautions: step 1, image 2 of 2
    • Before you begin, ensure that the engine is off and cool to the touch.
  2. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 2, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 2, image 2 of 2
    • Locate the gas cutoff valve and flip the switch to the left to shut it.
  3. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 3, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 3, image 2 of 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Remove the intake guard: step 4, image 1 of 1
    • Use a 1/2 inch wrench to remove the intake guard bolt behind the front wheel.
  5. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 5, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 5, image 2 of 2
    • Use a 1/2 inch socket to remove the five bolts securing the intake guard.
  6. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 6, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 6, image 2 of 2
    • Remove the intake guard.
  7. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Remove the fan blade: step 7, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement, Remove the fan blade: step 7, image 2 of 2
    • Use an impact wrench to remove the 5/8 inch bolt securing the fan blade to the spindle.
  8. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 8, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 8, image 2 of 2
    • Remove the fan plug bolt and fan plug.
  9. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 9, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 9, image 2 of 2
    • Remove the fan blade.
  10. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 10, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 10, image 2 of 2
    • Use a pair of pliers to remove the key from the spindle.
  11. Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 11, image 1 of 2 Little Wonder GX270 Honda Maximum Output Blower Fan Replacement: step 11, image 2 of 2
    • Remove the fan spacer.
    • Wipe the old grease off the spindle with a shop towel and apply new grease before installing the replacement parts.
Sam Omiotek
83,715 Reputation
290 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 755
