Logic Board Removal (Battery)
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Logic Board Removal (Battery), Safety precautions: step 1, image 1 of 2 Logic Board Removal (Battery), Safety precautions: step 1, image 2 of 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Logic Board Removal (Battery), Adhesive information: step 2, image 1 of 3 Logic Board Removal (Battery), Adhesive information: step 2, image 2 of 3 Logic Board Removal (Battery), Adhesive information: step 2, image 3 of 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Logic Board Removal (Battery), Apply a suction handle: step 3, image 1 of 2 Logic Board Removal (Battery), Apply a suction handle: step 3, image 2 of 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Logic Board Removal (Battery), Insert an opening pick: step 4, image 1 of 3 Logic Board Removal (Battery), Insert an opening pick: step 4, image 2 of 3 Logic Board Removal (Battery), Insert an opening pick: step 4, image 3 of 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Logic Board Removal (Battery), Separate the rear cover adhesive: step 5, image 1 of 3 Logic Board Removal (Battery), Separate the rear cover adhesive: step 5, image 2 of 3 Logic Board Removal (Battery), Separate the rear cover adhesive: step 5, image 3 of 3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Logic Board Removal (Battery): step 6, image 1 of 3 Logic Board Removal (Battery): step 6, image 2 of 3 Logic Board Removal (Battery): step 6, image 3 of 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Logic Board Removal (Battery): step 7, image 1 of 3 Logic Board Removal (Battery): step 7, image 2 of 3 Logic Board Removal (Battery): step 7, image 3 of 3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Logic Board Removal (Battery), Prop up the rear cover: step 8, image 1 of 3 Logic Board Removal (Battery), Prop up the rear cover: step 8, image 2 of 3 Logic Board Removal (Battery), Prop up the rear cover: step 8, image 3 of 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Logic Board Removal (Battery), Remove the wireless charging assembly: step 9, image 1 of 2 Logic Board Removal (Battery), Remove the wireless charging assembly: step 9, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
  10. Logic Board Removal (Battery): step 10, image 1 of 3 Logic Board Removal (Battery): step 10, image 2 of 3 Logic Board Removal (Battery): step 10, image 3 of 3
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
  11. Logic Board Removal (Battery), Disconnect the rear cover: step 11, image 1 of 3 Logic Board Removal (Battery), Disconnect the rear cover: step 11, image 2 of 3 Logic Board Removal (Battery), Disconnect the rear cover: step 11, image 3 of 3
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
  12. Logic Board Removal (Battery), Remove the rear cover: step 12, image 1 of 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
  13. Logic Board Removal (Battery), Remove the cable cover: step 13, image 1 of 2 Logic Board Removal (Battery), Remove the cable cover: step 13, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two screws securing the cable cover:
    • One 2.3 mm‑long screw
    • One 5.4 mm‑long screw
  14. Logic Board Removal (Battery): step 14, image 1 of 2 Logic Board Removal (Battery): step 14, image 2 of 2
    • Use tweezers or your fingers to remove the cable cover.
  15. Logic Board Removal (Battery), Disconnect the battery: step 15, image 1 of 3 Logic Board Removal (Battery), Disconnect the battery: step 15, image 2 of 3 Logic Board Removal (Battery), Disconnect the battery: step 15, image 3 of 3
    • Insert the point of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
  16. Logic Board Removal (Battery), Remove the 5G mmWave cover screw: step 16, image 1 of 2 Logic Board Removal (Battery), Remove the 5G mmWave cover screw: step 16, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.4 mm‑long screw securing the mmWave antenna cover.
  17. Logic Board Removal (Battery), Unclip the 5G mmWave cover: step 17, image 1 of 3 Logic Board Removal (Battery), Unclip the 5G mmWave cover: step 17, image 2 of 3 Logic Board Removal (Battery), Unclip the 5G mmWave cover: step 17, image 3 of 3
    • Insert the point of a spudger under the clip near the bottom left corner of the mmWave antenna cover and pry up to unclip it.
  18. Logic Board Removal (Battery), Remove the 5G mmWave cover: step 18, image 1 of 2 Logic Board Removal (Battery), Remove the 5G mmWave cover: step 18, image 2 of 2
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
  19. Logic Board Removal (Battery), Disconnect the 5G mmWave antenna: step 19, image 1 of 2 Logic Board Removal (Battery), Disconnect the 5G mmWave antenna: step 19, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
  20. Logic Board Removal (Battery), Disconnect the front facing camera: step 20, image 1 of 2 Logic Board Removal (Battery), Disconnect the front facing camera: step 20, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
  21. Logic Board Removal (Battery), Remove the 5G mmWave antenna screw: step 21, image 1 of 3 Logic Board Removal (Battery), Remove the 5G mmWave antenna screw: step 21, image 2 of 3 Logic Board Removal (Battery), Remove the 5G mmWave antenna screw: step 21, image 3 of 3
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.3 mm‑long screw securing the mmWave antenna.
  22. Logic Board Removal (Battery), Remove the 5G mmWave antenna: step 22, image 1 of 2 Logic Board Removal (Battery), Remove the 5G mmWave antenna: step 22, image 2 of 2
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
  23. Logic Board Removal (Battery), Disconnect the logic board cables: step 23, image 1 of 3 Logic Board Removal (Battery), Disconnect the logic board cables: step 23, image 2 of 3 Logic Board Removal (Battery), Disconnect the logic board cables: step 23, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the press connector near the bottom left corner of the logic board.
    • Use the point of a spudger to disconnect the press connector just to the right of the previous one.
  24. Logic Board Removal (Battery): step 24, image 1 of 2 Logic Board Removal (Battery): step 24, image 2 of 2
    • Insert the tip of an opening pick under the top edge of the press connector near the bottom right corner of the logic board.
    • Be very careful not to damage the small, surface-mounted components to the right of the connector.
    • Use the pick to pry up and disconnect the press connector.
  25. Logic Board Removal (Battery), Move the charging board cover: step 25, image 1 of 2 Logic Board Removal (Battery), Move the charging board cover: step 25, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 4.3 mm‑long screws securing the charging board cover.
  26. Logic Board Removal (Battery): step 26, image 1 of 3 Logic Board Removal (Battery): step 26, image 2 of 3 Logic Board Removal (Battery): step 26, image 3 of 3
    • Use your fingers to pull the right edge of the charging board cover towards the top of your phone to unclip the left side of the cover.
    • Flip the cover away from the charging board so you can access its press connectors.
  27. Logic Board Removal (Battery), Disconnect the charging board cables: step 27, image 1 of 3 Logic Board Removal (Battery), Disconnect the charging board cables: step 27, image 2 of 3 Logic Board Removal (Battery), Disconnect the charging board cables: step 27, image 3 of 3
    • Be very careful not to damage any of the small, surface‑mounted components on the charging board.
    • Use the point of a spudger to pry up and disconnect the three press connectors on the top edge of the charging board.
  28. Logic Board Removal (Battery), Remove the left interconnect cable: step 28, image 1 of 1
    • Use your fingers to remove the left interconnect cable.
  29. Logic Board Removal (Battery), Remove the right interconnect cable: step 29, image 1 of 2 Logic Board Removal (Battery), Remove the right interconnect cable: step 29, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.5 mm‑long screws securing the bottom of the right interconnect cable.
  30. Logic Board Removal (Battery): step 30, image 1 of 1
    • Use your fingers to remove the right interconnect cable.
  31. Logic Board Removal (Battery), Remove the antenna board cover: step 31, image 1 of 2 Logic Board Removal (Battery), Remove the antenna board cover: step 31, image 2 of 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.4 mm‑long screw securing the antenna cover in the top left corner.
  32. Logic Board Removal (Battery): step 32, image 1 of 2 Logic Board Removal (Battery): step 32, image 2 of 2
    • Use tweezers or your fingers to remove the cover.
  33. Logic Board Removal (Battery), Disconnect the antenna board: step 33, image 1 of 3 Logic Board Removal (Battery), Disconnect the antenna board: step 33, image 2 of 3 Logic Board Removal (Battery), Disconnect the antenna board: step 33, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the autofocus sensor press connector from the top left corner.
    • Carefully move the cable out of the way so you can access the metal antenna connector underneath.
  34. Logic Board Removal (Battery): step 34, image 1 of 2 Logic Board Removal (Battery): step 34, image 2 of 2
    • Slide one arm of your angled tweezers under the metal neck of the antenna connector and lift straight up to disconnect it.
    • To reconnect, hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
  35. Logic Board Removal (Battery), Remove the logic board: step 35, image 1 of 3 Logic Board Removal (Battery), Remove the logic board: step 35, image 2 of 3 Logic Board Removal (Battery), Remove the logic board: step 35, image 3 of 3
    • Use a spudger to pry up the top edge of the logic board until you can grip it with your fingers.
    • Grip the right side of the logic board and remove it, being careful not to snag the front facing camera and battery cables.
    • During reassembly, hold the front facing camera cable out of the way and lower the logic board into place.
  36. Logic Board Removal (Battery), Reassembly information: step 36, image 1 of 3 Logic Board Removal (Battery), Reassembly information: step 36, image 2 of 3 Logic Board Removal (Battery), Reassembly information: step 36, image 3 of 3
    • During reassembly:
    • Check the condition of the logic board thermal pad—it will either be on the bottom of the logic board or on the frame.
    • If the pad is undamaged, skip the rest of this step.
    • If the pad is damaged, use the flat end of a spudger to scrape it up and remove it.
    • Use isopropyl alcohol (greater than 90%) and a microfiber cloth to remove all thermal pad residue from the frame and bottom of the logic board.
    • Apply a new thermal pad to its spot on the frame.
Finish Line
Spencer Day
155,503 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,790 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 94
