Logitech B100 Mouse - Disassembly
  1. Logitech B100 Mouse - Disassembly, Mouse: step 1, image 1 of 1
    • Remove one Phillips screw.
    • Very nice: You don't have to remove mouse feet to reach screws.
  2. Logitech B100 Mouse - Disassembly: step 2, image 1 of 3 Logitech B100 Mouse - Disassembly: step 2, image 2 of 3 Logitech B100 Mouse - Disassembly: step 2, image 3 of 3
    • Open the gap with your fingernail or the flat end of a spudger.
    • Slide the upper part in direction of the mouse calbe. Use your other hand to hold the lower part of the mouse.
    • Remove the upper part and put it aside.
  3. Logitech B100 Mouse - Disassembly: step 3, image 1 of 3 Logitech B100 Mouse - Disassembly: step 3, image 2 of 3 Logitech B100 Mouse - Disassembly: step 3, image 3 of 3
    • Lift the assembly of the mouse wheel.
    • You can see two springs.
    • Spring for haptical feedback while scrolling the mouse wheel.
    • Spring for reset the position after a mouse wheel click.
  4. Logitech B100 Mouse - Disassembly: step 4, image 1 of 2 Logitech B100 Mouse - Disassembly: step 4, image 2 of 2
    • Pull out the USB cable from the bracket.
    • Optional: Unplug the connector from the board.
  5. Logitech B100 Mouse - Disassembly: step 5, image 1 of 3 Logitech B100 Mouse - Disassembly: step 5, image 2 of 3 Logitech B100 Mouse - Disassembly: step 5, image 3 of 3
    • Lift the board in the front and pull it out in forward direction.
  6. Logitech B100 Mouse - Disassembly: step 6, image 1 of 2 Logitech B100 Mouse - Disassembly: step 6, image 2 of 2
    • Reference pictures of the board.
  7. Logitech B100 Mouse - Disassembly, Optional for cleaning: step 7, image 1 of 3 Logitech B100 Mouse - Disassembly, Optional for cleaning: step 7, image 2 of 3 Logitech B100 Mouse - Disassembly, Optional for cleaning: step 7, image 3 of 3
    • Find the four plastic clips. They hold the two upper parts together.
    • Release the two plastic clips at the back.
    • Release the two plastic clips in the middle.
  8. Logitech B100 Mouse - Disassembly: step 8, image 1 of 2 Logitech B100 Mouse - Disassembly: step 8, image 2 of 2
    • Increase the already present gap.
    • Push both parts apart.
  9. Logitech B100 Mouse - Disassembly: step 9, image 1 of 1
    • Overview of all parts.
Reverse the steps to reassemble your device.
Special thanks to these translators:
de en
100%
Xare is helping us fix the world! Want to contribute?
Start translating ›
Xare
2,368 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 42
Past 30 Days: 158
All Time: 2,364
