Logitech C920 Webcam Disassembly
  1. Logitech C920 Webcam Disassembly, Logitech C920 Webcam Disassembly: step 1, image 1 of 2 Logitech C920 Webcam Disassembly, Logitech C920 Webcam Disassembly: step 1, image 2 of 2
    • On the bottom side of the webcam, remove the stickers from both sides
  2. Logitech C920 Webcam Disassembly: step 2, image 1 of 1
    • Remove the four Phillips screws.
    • Press into the holes to unlock the side covers.
  3. Logitech C920 Webcam Disassembly: step 3, image 1 of 2 Logitech C920 Webcam Disassembly: step 3, image 2 of 2
    • Once you’ve removed the side covers, unscrew all eight Phillips screws highlighted.
  4. Logitech C920 Webcam Disassembly: step 4, image 1 of 3 Logitech C920 Webcam Disassembly: step 4, image 2 of 3 Logitech C920 Webcam Disassembly: step 4, image 3 of 3
    • Remove the lens's cover.
    • Remove the five Phillips screws of the metal bracket.
    • Remove the rubber pieces of both microphones (one on each side).
  5. Logitech C920 Webcam Disassembly: step 5, image 1 of 1
    • Carefully remove the metal supports from the webcam's base.
  6. Logitech C920 Webcam Disassembly: step 6, image 1 of 2 Logitech C920 Webcam Disassembly: step 6, image 2 of 2
    • Carefully remove the base of the plastic support. Loosen the three screws that secure the electronic circuit.
  7. Logitech C920 Webcam Disassembly: step 7, image 1 of 1
    • Disconnect the USB cable connector.
  8. Logitech C920 Webcam Disassembly: step 8, image 1 of 1
    • Remove the electronic circuit.
  9. Logitech C920 Webcam Disassembly: step 9, image 1 of 2 Logitech C920 Webcam Disassembly: step 9, image 2 of 2
    • Release the clip that secures the cable holder. Pull this cable holder out of the camera.
  10. Logitech C920 Webcam Disassembly: step 10, image 1 of 2 Logitech C920 Webcam Disassembly: step 10, image 2 of 2
    • Front and back images of the webcam's electronic circuit board.
  11. Logitech C920 Webcam Disassembly: step 11, image 1 of 1
    • The problem was the broken cable on the back of the camera. I've cut the faulty part and redid the connections by soldering them and insulated them with heat shrink tubes.
  12. Logitech C920 Webcam Disassembly: step 12, image 1 of 1
    • The repaired cable is reattached to the camera. Wrapped it with some masking tape. Camera tested: OK!
    • Assemble the webcam following the steps in a reverse order.
40 other people completed this guide.
Special thanks to these translators:
pt en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Jose Gustavo Abreu Murta
4,970 Reputation
9 Guides authored
31 Guide Comments
Excellent! Helped me figure out how to get the base off to mount it to an ikea worklamp as a hacky boom.
Cory Elsmore - Reply
Can you post a guide or technique of the process?
Or share some photos? (On meta.ifixit.com)
Kind-hearted, spirited Man -
Cory,
I did not understand your question.
This repair guide contains several photos.
Jose Gustavo Abreu Murta -
thanks for an excellent guide . I am now more positive that it is something I can perform now. Many thanks
Graham Klaer - Reply
im having trouble releasing the 4 screws on step 3!!! the screw driver keeps slipping and i’ve tried a few and another webcam…
Dojo Mats - Sunny - Reply
Past 24 Hours: 20
Past 7 Days: 165
Past 30 Days: 1,038
All Time: 67,370
