Logitech Circle Ribbon Cable Replacement
  1. Logitech Circle Ribbon Cable Replacement, Ribbon Cable: step 1, image 1 of 2 Logitech Circle Ribbon Cable Replacement, Ribbon Cable: step 1, image 2 of 2
    • Wedge the plastic opening tool under the black circle lens and gently pry it off.
    • The lens is only attached with sticky tape and should remove relatively easily.
  2. Logitech Circle Ribbon Cable Replacement: step 2, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 2, image 2 of 2
    • Remove the four 3mm Phillips #0 screws that hold down the first ring.
  3. Logitech Circle Ribbon Cable Replacement: step 3, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 3, image 2 of 2
    • Remove the four 3mm Phillips #0 screws that hold down the second ring.
  4. Logitech Circle Ribbon Cable Replacement: step 4, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 4, image 2 of 2
    • Remove the four 3mm Phillips #0 screws that hold down the final ring. Do not remove the lens/battery bundle yet.
    • The lens/battery bundle is attached to the base by a ribbon cable that can break, so be very careful handling the circle.
  5. Logitech Circle Ribbon Cable Replacement: step 5, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 5, image 2 of 2
    • Gently remove the lens/battery bundle from the base of the circle, being mindful of the ribbon cable.
  6. Logitech Circle Ribbon Cable Replacement: step 6, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 6, image 2 of 2
    • Gently pull the ribbon cable loose from the lens/battery bundle.
    • While this is not an entirely necessary step, it helps to ensure the ribbon cable will not break during the rest of the replacement.
  7. Logitech Circle Ribbon Cable Replacement: step 7, image 1 of 3 Logitech Circle Ribbon Cable Replacement: step 7, image 2 of 3 Logitech Circle Ribbon Cable Replacement: step 7, image 3 of 3
    • Once the old ribbon cable has been detached from the lens/battery bundle it's time to release the other side from the base.
    • Locate the screws holding the base together by feeling for the soft spots underneath the manufacturer's sticker. Punch through with your screwdriver and remove the three 3mm Phillips #0 screws.
    • The two pieces of the base can now be easily pulled apart.
  8. Logitech Circle Ribbon Cable Replacement: step 8, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 8, image 2 of 2
    • Gently pull the ribbon cable loose from its connection to the base.
  9. Logitech Circle Ribbon Cable Replacement: step 9, image 1 of 2 Logitech Circle Ribbon Cable Replacement: step 9, image 2 of 2
    • Slide the push pin holding the plastic connector/ribbon cable in place out on both sides.
  10. Logitech Circle Ribbon Cable Replacement: step 10, image 1 of 1
    • Remove the black plastic connector and the two springs from the base of the device.
  11. Logitech Circle Ribbon Cable Replacement: step 11, image 1 of 1
    • Reach inside the circle and pull the ribbon cable free from the device.
Haley Williams
112 Reputation
1 Guide authored
6 Guide Comments
where can I buy such a cable?
kersop@gmail.com
Nico Kersop - Reply Share
The cable I received from China is not the right one. Where do you buy the correct one?
Helen - Reply Share
Can you advise where to buy the correct cable?
Michele Ingratta - Reply Share
I have cable has beark off. I need that cable.
Where can I find
Alican Döşlü - Reply Share
i also need that cable
l_samin - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 46
All Time: 2,466
