Logitech Dual Action Joystick Replacement
  1. Logitech Dual Action Joystick Replacement, Taking out the screws: step 1, image 1 of 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw marked with orange.
  2. Logitech Dual Action Joystick Replacement, Opening the controller: step 2, image 1 of 3 Logitech Dual Action Joystick Replacement, Opening the controller: step 2, image 2 of 3 Logitech Dual Action Joystick Replacement, Opening the controller: step 2, image 3 of 3
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  3. Logitech Dual Action Joystick Replacement, Replacing the joystick: step 3, image 1 of 2 Logitech Dual Action Joystick Replacement, Replacing the joystick: step 3, image 2 of 2
    • With the case off, the joysticks can be removed by pulling them upward.
    • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
    • Make sure that the cut-out side of the joystick is towards the outsides of the device.
Finish Line
24 other people completed this guide.
Brian Neuman
1,082 Reputation
3 Guides authored
USF Tampa, Team 7-4, Remmell Winter 2015 Member of USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Members
5 Guides authored
5 Guide Comments
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - Reply
will the buttons still work if you put it all back?
Atsuku - Reply
When you press the buttons, they don't work, but when you press hard, they only work, and they don't work just by pressing normally?
[deleted] - Reply
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
Mohamed Abass Sylla - Reply
Past 24 Hours: 5
Past 7 Days: 38
Past 30 Days: 186
All Time: 13,076
