Logitech Dual Action disassembly
  1. Logitech Dual Action disassembly, Taking out the screws: step 1, image 1 of 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw circled in orange.
  2. Logitech Dual Action disassembly, Opening the controller: step 2, image 1 of 3 Logitech Dual Action disassembly, Opening the controller: step 2, image 2 of 3 Logitech Dual Action disassembly, Opening the controller: step 2, image 3 of 3
    • With the screws removed, turn the controller upside down. Insert the iFixit opening tool between the top and bottom casing to pry them apart.
    • Separate the top and bottom casing.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the four circular buttons labeled 1-4, four smaller circular buttons for the D-Pad, and three rounded rectangular buttons.
  3. Logitech Dual Action disassembly, Cleaning the buttons: step 3, image 1 of 1
    • Turn the top casing of the controller over to remove all the buttons.
    • Wipe each individual button with a piece of cloth and rubbing alcohol.
Finish Line
12 other people completed this guide.
Brian Neuman
1,082 Reputation
3 Guides authored
USF Tampa, Team 7-4, Remmell Winter 2015 Member of USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 Members
5 Guides authored
1 Guide Comment
What is the right side of dpad buttons when put back?
There a polish side and another with fabric numbers. What side have to be up and down?
rodrigomarshmallow - Reply
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 102
All Time: 7,778
