Logitech Extreme 3D Pro Base Button Circuit Board Replacement
Emanuel Canela
Emanuel Canela and one other contributor
Last updated on June 26, 2018
5 - 10 minutes
Easy
Introduction
Go to step 1
If one of the six buttons on the base of joystick no longer works, it may be necessary to replace the circuit board.
Tools
  1. Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Disassembly of the handle: step 1, image 1 of 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 2, image 1 of 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 3, image 1 of 2 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 3, image 2 of 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Disassembly of the base: step 4, image 1 of 1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
    There is a 9th screw that you need to remove near the cable
    gigakoulis - Reply
    I need a wiring diagram for the Logitech 3D Pro, I'm changing the Pots.
    Melvin L. Willms - Reply
  5. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 5, image 1 of 3 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 5, image 2 of 3 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 5, image 3 of 3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Base Button Circuit Board: step 6, image 1 of 2 Logitech Extreme 3D Pro Base Button Circuit Board Replacement, Base Button Circuit Board: step 6, image 2 of 2
    • Remove this wire plug head from this circuit board.
    • Removing this wire frees the base piece to make working on it easier.
  7. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 7, image 1 of 1
    • Remove the two 10mm Phillips #1 screws from the button board.
  8. Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 8, image 1 of 2 Logitech Extreme 3D Pro Base Button Circuit Board Replacement: step 8, image 2 of 2
    • Lift up the button board.
    • Disconnect the button board.
5 other people completed this guide.
Emanuel Canela
1,321 Reputation
7 Guides authored
USF Tampa, Team S7-G1, Passmore Spring 2018 Member of USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Members
7 Guides authored
4 Comments
What's the dimensions of those switches? Have you managed to find them online? I have 2 faulty ones on my 2005 Extreme 3D Pro
Michael Tyers - Reply
I have just recently changed 6 of them, which shown at step 8 at this guide. Now it works as good as new.
You can find them as “tact switch” (or tactile switch) at online for very cheap prices. Dimensions are milimeter, 6x6 mm and button height is 4.3 mm. i think these are shortest of 6x6 button family.
Search at Google for “6x6x4 tact switch”. For referance:
https://n11scdn1.akamaized.net/a1/1024/e...
Here is how it looks after i changed tem: https://imgur.com/a/DhemkSh
Gökalp Topyan -
Is there anywhere I can get the logic board only. Thanks.
Calvin Lim - Reply
@mikejt86 Thank you for posting this. I have two bad switches, #7 & #12 not working. I have disassembled it to test and strangely find no switching action on any of the switches with my multimeter in continuity mode. They test as if pressing the switch does nothing, which seems odd. Did you test your switches before replacing them? I am more curious than anything at this point.
Jssamp - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 55
All Time: 4,183
