Logitech Extreme 3D Pro Disassembly of the base
  1. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the handle: step 1, image 1 of 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the base: step 2, image 1 of 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the base: step 3, image 1 of 2 Logitech Extreme 3D Pro Disassembly of the base: step 3, image 2 of 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Disassembly of the base, Disassembly of the base: step 4, image 1 of 1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Disassembly of the base: step 5, image 1 of 3 Logitech Extreme 3D Pro Disassembly of the base: step 5, image 2 of 3 Logitech Extreme 3D Pro Disassembly of the base: step 5, image 3 of 3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
3 other people completed this guide.
Emanuel Canela
1,297 Reputation
7 Guides authored
USF Tampa, Team S7-G1, Passmore Spring 2018 Member of USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Members
7 Guides authored
One Comment
And you didn’t even finish the repair. Thanks for nothing. :(
Jesse James - Reply
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 81
All Time: 3,900
