Logitech Extreme 3D Pro Main Joystick Spring Replacement
  1. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the handle: step 1, image 1 of 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 2, image 1 of 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 3, image 1 of 2 Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 3, image 2 of 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Disassembly of the base: step 4, image 1 of 1
    • Remove the eight 10mm Phillips #1 screws from the bottom.
  5. Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 5, image 1 of 3 Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 5, image 2 of 3 Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 5, image 3 of 3
    • Flip the joystick upright.
    • Lift up the sliver base cover and feed the loose circuit board through.
    • Careful with the wires still attached to the silver base cover from the bottom of the joystick.
  6. Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: step 6, image 1 of 2 Logitech Extreme 3D Pro Main Joystick Spring Replacement, Main Joystick Spring: step 6, image 2 of 2
    • Disconnect the wire from the motherboard.
  7. Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 7, image 1 of 2 Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 7, image 2 of 2
    • Remove this plug from the motherboard.
  8. Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 8, image 1 of 2 Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 8, image 2 of 2
    • Remove the four 10mm Phillips #1 screws from the joystick base.
  9. Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 9, image 1 of 1
    • Remove the joystick assembly.
  10. Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 10, image 1 of 1
    • Remove the white plastic piece on top of the spring.
    • The white plastic will be covered in a lubricant.
  11. Logitech Extreme 3D Pro Main Joystick Spring Replacement: step 11, image 1 of 1
    • Remove the Spring
    • The spring will be covered in lubricant.
5 other people completed this guide.
Emanuel Canela
1,297 Reputation
7 Guides authored
USF Tampa, Team S7-G1, Passmore Spring 2018 Member of USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Members
7 Guides authored
6 Comments
um, what kind of spring is that and where/how would I get a replacement?
Swift Foxe - Reply
same question here
Robbert Sprezzatura -
Where can I find a replacement spring?
ande3224@bellsouth.net - Reply
Anyone found a source for replacement springs?
Chandler - Reply
You can cut the top 360 degrees off the spring with a Dremel cutoff tool, that reduces the work require to operate the stick by about half.
Frank Clarke - Reply
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 133
All Time: 11,588
