Logitech G1 Optical Mouse Scroll Wheel Replacement
  1. Logitech G1 Optical Mouse Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 1
    • Remove one screw at the bottom of the mouse.
  2. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 2, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 2, image 2 of 2
    • Pull the top of the mouse lid gently to separate it from the rest of the mouse.
    • Potential for device damage: The lid and the body are connected with a wire, so separate them gently.
  3. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 3, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 3, image 2 of 2
    • Pull the white connector from the circuit board.
    • Be sure the two small holes in the connector are positioned at the top when reassembling.
  4. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 4, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 4, image 2 of 2
    • Carefully pull the scroll wheel up.
    • The long parts of the spring should be in the southeast and southwest directions when reassembling.
  5. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 5, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 5, image 2 of 2
    • Carefully remove the two Phillips #0 screws.
  6. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 6, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 6, image 2 of 2
    • Clean the mouse case, lid, and module with a dry cotton swab or soft brush.
    • Potential for device damage: Do not use water or an iron brush to clean it.
  7. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 7, image 1 of 2 Logitech G1 Optical Mouse Scroll Wheel Replacement: step 7, image 2 of 2
    • Place the new scroll wheel into the mouse.
  8. Logitech G1 Optical Mouse Scroll Wheel Replacement: step 8, image 1 of 1
    • The spring should be inserted into a small groove.
    • The spring can be inserted after combining the mouse body.
Finish Line
4 other people completed this guide.
wooseok yang
358 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 38
All Time: 2,071
