Logitech G29 Driving Force Paddle Assembly Replacement
  1. Logitech G29 Driving Force Paddle Assembly Replacement, Paddle Assembly: step 1, image 1 of 1
    • Remove the six 32 mm hex screws from the faceplate of the steering wheel.
  2. Logitech G29 Driving Force Paddle Assembly Replacement: step 2, image 1 of 1
    • Remove the six 10 mm #00 Phillips screws from the back of the steering wheel.
    • Gently lift off the steering wheel from the hub.
  3. Logitech G29 Driving Force Paddle Assembly Replacement: step 3, image 1 of 1
    • Carefully unplug the wire connector from the motherboard of the steering wheel.
  4. Logitech G29 Driving Force Paddle Assembly Replacement: step 4, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the three 30 mm screws that are behind the steering wheel.
  5. Logitech G29 Driving Force Paddle Assembly Replacement: step 5, image 1 of 1
    • Gently pull the paddle assembly off from the base of the device and carefully thread the connector through the hole in the center.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 46
Past 30 Days: 207
All Time: 6,988
