Logitech G305 Feet Replacement
  1. Logitech G305 Feet Replacement, Turn off your mouse: step 1, image 1 of 2 Logitech G305 Feet Replacement, Turn off your mouse: step 1, image 2 of 2
    • Slide your mouse's power switch to the left so it's in the OFF position.
    • A red indicator should be visible beneath the switch.
    • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
  2. Logitech G305 Feet Replacement, Remove the mouse feet: step 2, image 1 of 2 Logitech G305 Feet Replacement, Remove the mouse feet: step 2, image 2 of 2
    • The feet are secured to the bottom of the mouse with adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
    • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
  3. Logitech G305 Feet Replacement: step 3, image 1 of 3 Logitech G305 Feet Replacement: step 3, image 2 of 3 Logitech G305 Feet Replacement: step 3, image 3 of 3
    • The feet have two layers—a rubberized one and an adhesive pad underneath.
    • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
    • Carefully slide the point of a spudger under one of the feet, making sure it goes under both the foot and its adhesive pad.
    • If you're just removing the feet to open the mouse, you don't need to remove the circular one below the power switch.
    • Gently slide the spudger farther under the foot and lift to remove it.
    • If the rubber layer separates from its adhesive pad, use the same process to remove the pad.
  4. Logitech G305 Feet Replacement: step 4, image 1 of 3 Logitech G305 Feet Replacement: step 4, image 2 of 3 Logitech G305 Feet Replacement: step 4, image 3 of 3
    • Repeat the previous step to remove the remaining feet.
  5. Logitech G305 Feet Replacement, Reassembly information: step 5, image 1 of 3 Logitech G305 Feet Replacement, Reassembly information: step 5, image 2 of 3 Logitech G305 Feet Replacement, Reassembly information: step 5, image 3 of 3
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • If there's any adhesive residue left, use isopropyl alcohol and a microfiber cloth to remove it. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
Spencer Day
155,482 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,790 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 31
Past 30 Days: 198
All Time: 2,302
