Logitech G400s Scroll Wheel Replacement
  1. Logitech G400s Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 1
    • Use a flathead screwdriver or your fingernail to remove the mouse feet.
    • Be careful to remove any film left by the mouse feet as well.
  2. Logitech G400s Scroll Wheel Replacement: step 2, image 1 of 1
    • Remove the bottom mouse foot using a Jimmy and the same technique as in Step 1.
  3. Logitech G400s Scroll Wheel Replacement: step 3, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the three 5 mm Philips screws on the bottom surface.
  4. Logitech G400s Scroll Wheel Replacement: step 4, image 1 of 1
    • Gently pull the upper shell away from the bottom platform.
  5. Logitech G400s Scroll Wheel Replacement: step 5, image 1 of 1
    • This is what the G400s will look like when the top shell is taken off.
  6. Logitech G400s Scroll Wheel Replacement: step 6, image 1 of 1
    • Simply lift the scroll wheel out of the compartment it sits in. It can then be cleaned or replaced as desired.
2 other people completed this guide.
Max Evans
433 Reputation
3 Guides authored
USF Tampa, Team 16-7, Eyestone Fall 2016 Member of USF Tampa, Team 16-7, Eyestone Fall 2016
USFT-EYESTONE-F16S16G7
1 Member
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 4,239
