Logitech G432 Audio Cable Replacement
  1. Logitech G432 Audio Cable Replacement, Earpad Cushions: step 1, image 1 of 2 Logitech G432 Audio Cable Replacement, Earpad Cushions: step 1, image 2 of 2
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Audio Cable Replacement, Audio Cable: step 2, image 1 of 3 Logitech G432 Audio Cable Replacement, Audio Cable: step 2, image 2 of 3 Logitech G432 Audio Cable Replacement, Audio Cable: step 2, image 3 of 3
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Audio Cable Replacement: step 3, image 1 of 1
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
  4. Logitech G432 Audio Cable Replacement: step 4, image 1 of 1
    • Raise the small component fastened to the wiring at the bottom of the earpiece to reveal each wire.
  5. Logitech G432 Audio Cable Replacement: step 5, image 1 of 1
    • Extend the wiring to expose the tiny knots located along the audio cable.
    • Unravel the knots to disconnect the wires using a soldering iron, making it possible to connect the new audio cable.
Lara Vasquez
412 Reputation
4 Guides authored
Marist, Team 1-2, Chaterdon Spring 2023 Member of Marist, Team 1-2, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G2
3 Members
9 Guides authored
2 Guide Comments
Vous pourriez mettre la référence du câble ?
Jean Morlet - Reply
pour le moins tuto incomplet , on aimerai voir effectivement le replacement du cable, en effet, le cable d'origine comporte 6 conducteurs alors que les cables de remplacement n'en comportent que 4. La réparation ne s'arrete donc pas à remplacer les fils un par un (en plus la couleur des fils n'est pas la meme qu'à l'origine) il faut modifier le cablage d'origine : déplacer une tresse de masse et souder 2 straps......
marc miettaux - Reply
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 101
All Time: 4,076
