Logitech G432 Microphone Replacement
  1. Logitech G432 Microphone Replacement, Earpad Cushions: step 1, image 1 of 2 Logitech G432 Microphone Replacement, Earpad Cushions: step 1, image 2 of 2
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Microphone Replacement, Microphone: step 2, image 1 of 3 Logitech G432 Microphone Replacement, Microphone: step 2, image 2 of 3 Logitech G432 Microphone Replacement, Microphone: step 2, image 3 of 3
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Microphone Replacement: step 3, image 1 of 2 Logitech G432 Microphone Replacement: step 3, image 2 of 2
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
    • Use an iFixit opening tool to separate the four black tabs by pushing them apart.
  4. Logitech G432 Microphone Replacement: step 4, image 1 of 2 Logitech G432 Microphone Replacement: step 4, image 2 of 2
    • To adjust or remove the microphone piece, use a Phillips #0 Screwdriver to tighten or loosen the 1.0 mm screw that holds it in place.
Lara Vasquez
412 Reputation
4 Guides authored
Marist, Team 1-2, Chaterdon Spring 2023 Member of Marist, Team 1-2, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G2
3 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 51
All Time: 1,910
