Logitech G432 Volume Button Replacement
  1. Logitech G432 Volume Button Replacement, Earpad Cushions: step 1, image 1 of 2 Logitech G432 Volume Button Replacement, Earpad Cushions: step 1, image 2 of 2
    • Carefully lift the cushion upward using your hands.
  2. Logitech G432 Volume Button Replacement, Volume Button: step 2, image 1 of 3 Logitech G432 Volume Button Replacement, Volume Button: step 2, image 2 of 3 Logitech G432 Volume Button Replacement, Volume Button: step 2, image 3 of 3
    • Remove the three 1.0 mm screws from the edge of the earpiece using a Phillips #0 screwdriver.
    • Use the pointed end of a spudger to remove the black sticker covering the fourth screw.
    • Remove the single 1.0 mm screw from beneath the sticker using a Phillips #0 screwdriver.
  3. Logitech G432 Volume Button Replacement: step 3, image 1 of 1
    • Gently open the headpiece to prevent accidentally pulling apart any of the internal wiring.
  4. Logitech G432 Volume Button Replacement: step 4, image 1 of 2 Logitech G432 Volume Button Replacement: step 4, image 2 of 2
    • To adjust and fix the volume button, use a Phillips #0 screwdriver to tighten, loosen, or remove the 1.0 mm screw located on the left side.
Lara Vasquez
412 Reputation
4 Guides authored
Marist, Team 1-2, Chaterdon Spring 2023 Member of Marist, Team 1-2, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G2
3 Members
9 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 30
All Time: 975
