Logitech G502 Hero Feet Replacement
  1. Logitech G502 Hero Feet Replacement, Prepare your mouse for disassembly: step 1, image 1 of 1
    • Before starting your repair, unplug the mouse.
    • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
  2. Logitech G502 Hero Feet Replacement, Remove the feet: step 2, image 1 of 2 Logitech G502 Hero Feet Replacement, Remove the feet: step 2, image 2 of 2
    • The feet are secured to the bottom of the mouse with adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
    • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
  3. Logitech G502 Hero Feet Replacement: step 3, image 1 of 3 Logitech G502 Hero Feet Replacement: step 3, image 2 of 3 Logitech G502 Hero Feet Replacement: step 3, image 3 of 3
    • The feet have two layers—a rubberized one and an adhesive pad underneath.
    • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
    • Carefully slide the point of a spudger under the large foot near the front of the mouse, making sure it goes under both the foot and its adhesive pad.
    • The foot recesses have a small notch that makes it easier to slide your spudger under.
    • Gently slide the spudger farther under the foot and lift until you can grip the pad with your fingers.
  4. Logitech G502 Hero Feet Replacement: step 4, image 1 of 3 Logitech G502 Hero Feet Replacement: step 4, image 2 of 3 Logitech G502 Hero Feet Replacement: step 4, image 3 of 3
    • Peel up and remove the foot.
    • If the rubber layer separates from its adhesive pad, use the same process to remove the pad.
  5. Logitech G502 Hero Feet Replacement: step 5, image 1 of 3 Logitech G502 Hero Feet Replacement: step 5, image 2 of 3 Logitech G502 Hero Feet Replacement: step 5, image 3 of 3
  6. Logitech G502 Hero Feet Replacement, Reassembly information: step 6, image 1 of 3 Logitech G502 Hero Feet Replacement, Reassembly information: step 6, image 2 of 3 Logitech G502 Hero Feet Replacement, Reassembly information: step 6, image 3 of 3
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
Spencer Day
156,140 Reputation
1,033 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,829 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 68
Past 30 Days: 317
All Time: 3,801
