Logitech G602 Motherboard Replacement
  1. Logitech G602 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Logitech G602 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Logitech G602 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Use a spudger to pry off all 4 mouse feet from under the mouse.
  2. Logitech G602 Motherboard Replacement: step 2, image 1 of 3 Logitech G602 Motherboard Replacement: step 2, image 2 of 3 Logitech G602 Motherboard Replacement: step 2, image 3 of 3
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from under the mouse feet.
  3. Logitech G602 Motherboard Replacement: step 3, image 1 of 2 Logitech G602 Motherboard Replacement: step 3, image 2 of 2
    • Use the blue spudger to prop open the battery port.
  4. Logitech G602 Motherboard Replacement: step 4, image 1 of 1
    • Remove the two AA batteries from the device.
  5. Logitech G602 Motherboard Replacement: step 5, image 1 of 2 Logitech G602 Motherboard Replacement: step 5, image 2 of 2
    • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the mouse’s internal hardware.
  6. Logitech G602 Motherboard Replacement: step 6, image 1 of 2 Logitech G602 Motherboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to grip and detach the white ribbon cable from the motherboard.
  7. Logitech G602 Motherboard Replacement: step 7, image 1 of 1
    • Use pliers to detach the white plug from the motherboard.
  8. Logitech G602 Motherboard Replacement: step 8, image 1 of 3 Logitech G602 Motherboard Replacement: step 8, image 2 of 3 Logitech G602 Motherboard Replacement: step 8, image 3 of 3
    • Use a Phillips #00 screwdriver to unscrew all 5 screws (3x5mm ) from the battery pack and motherboard.
  9. Logitech G602 Motherboard Replacement: step 9, image 1 of 1
    • Remove the motherboard from the mouse.
10 other people completed this guide.
5 Guide Comments
So can I buy a new motherboard? Where? I don’t see one available on this site.
Kat - Reply
Hi there Kat. Did you eventually find out where to get a new motherboard for your G602 mouse?
Luke Haasbroek -
Jerico, I’ve got a problem with my g602, as the mouse is depleting new batteries energy. I put new batteries on, and they are immediately recognized as “low batteries” by the mouse system, flashing the led indicator as low battery as well. Any thoughts?
Cristian Pereverzieff - Reply
I'm having the same problem. Where you able to fix the problem?
Christopher Flynn -
Completed successfully.
The hardest part was to find a spare mainboard.
Brendan - Reply
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 132
All Time: 12,067
