Logitech G703 Lightspeed Scroll Wheel Replacement
  1. Logitech G703 Lightspeed Scroll Wheel Replacement, Scroll Wheel: step 1, image 1 of 2 Logitech G703 Lightspeed Scroll Wheel Replacement, Scroll Wheel: step 1, image 2 of 2
    • Flip the switch to OFF before proceeding.
  2. Logitech G703 Lightspeed Scroll Wheel Replacement: step 2, image 1 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 2, image 2 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 2, image 3 of 3
    • Take the mouse skates off by using the flathead screwdriver.
    • If you intend to reuse the skates, it's recommended to warm them with a hairdryer to loosen the adhesive that secures them.
  3. Logitech G703 Lightspeed Scroll Wheel Replacement: step 3, image 1 of 2 Logitech G703 Lightspeed Scroll Wheel Replacement: step 3, image 2 of 2
    • Unscrew the four 5.4 mm countersunk screws using the Phillips #00 screwdriver.
  4. Logitech G703 Lightspeed Scroll Wheel Replacement: step 4, image 1 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 4, image 2 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 4, image 3 of 3
    • Pull apart the two halves of the mouse.
    • Be careful as you might break the tab to lock it back in place.
  5. Logitech G703 Lightspeed Scroll Wheel Replacement: step 5, image 1 of 2 Logitech G703 Lightspeed Scroll Wheel Replacement: step 5, image 2 of 2
    • Unscrew the two 4.9 mm countersunk screws using the Phillips #00 screwdriver.
  6. Logitech G703 Lightspeed Scroll Wheel Replacement: step 6, image 1 of 2 Logitech G703 Lightspeed Scroll Wheel Replacement: step 6, image 2 of 2
    • Unscrew the two 4.7 mm countersunk screws that secure the scroll wheel in using the Phillips #00 Screwdriver.
  7. Logitech G703 Lightspeed Scroll Wheel Replacement: step 7, image 1 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 7, image 2 of 3 Logitech G703 Lightspeed Scroll Wheel Replacement: step 7, image 3 of 3
    • Remove the rubber piece protecting the scroll wheel.
    • Detach the scroll wheel from the white plastic piece and replace.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
8 other people completed this guide.
Nail Ninja Johnson
370 Reputation
1 Guide authored
1 Guide Comment
¿Hola, cual es la altura del switch de la rueda del mouse?
Lautaro Tello (Ignar) - Reply
Past 24 Hours: 16
Past 7 Days: 105
Past 30 Days: 438
All Time: 8,535
