Logitech G710+ Disassembly
  1. Logitech G710+ Disassembly, Body: step 1, image 1 of 1
    • Remove 14 Phillips screws on the bottom of the kayboard.
    • Use a plastic tool to release the clips holding the case together.
    • There are two hidden clips above the left and right arrow keys.
    • Gently pry the two halves of the case apart.
    • Don't worry if any of the clips break, the screws will still hold the keyboard together once reassembled.
  2. Logitech G710+ Disassembly, Mother board: step 2, image 1 of 3 Logitech G710+ Disassembly, Mother board: step 2, image 2 of 3 Logitech G710+ Disassembly, Mother board: step 2, image 3 of 3
    • Unscrew the one screw holding on the ground and pull out the cables.
    • A good way of getting the cables out is by putting a screwdriver right there and twisting.
    • Unscrew this screw
  3. Logitech G710+ Disassembly, Scroll Wheel: step 3, image 1 of 1
    • The light thing comes out with a wiggle.
    • The scroll wheel on the other is harder because you have to melt or brake the supports off.
    • Then you have to get the wheel out which comes out with a very gentle wiggle.
  4. Logitech G710+ Disassembly, Pads: step 4, image 1 of 1
    • You can then take off the little pads
6 other people completed this guide.
Jackson Poer
683 Reputation
2 Guides authored
3 Guide Comments
Okay but then how do remove the Silver screw at the top of the keyboard, next to the grounded screw?
MaybeCrispyWaffles - Reply
step 2, 3rd picture “undo this screw” did not exist on my G710+. rather it had 3 screws one on the botom with a tab and one above the 2 key and one upper left of the insert key.
as for captains question, since i’m replying you get it after removing the motherboard from the back.
wildcat_15au - Reply
Is there a video or illustration defining how the space bar works and is installed or removed? I cant figure out where the stabilizer bar actually sits
Rick Painter - Reply
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 75
All Time: 9,285
