Logitech G903 Mouse Feet Replacement
  1. Logitech G903 Mouse Feet Replacement, Heat the mouse foot: step 1, image 1 of 1
    • The feet are secured to the bottom of the mouse with strong adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
    • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
  2. Logitech G903 Mouse Feet Replacement, Separate the mouse foot adhesive: step 2, image 1 of 3 Logitech G903 Mouse Feet Replacement, Separate the mouse foot adhesive: step 2, image 2 of 3 Logitech G903 Mouse Feet Replacement, Separate the mouse foot adhesive: step 2, image 3 of 3
    • The feet have two layers—a rubberized one and an adhesive pad underneath.
    • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
    • Slide the tip of an opening pick under an edge of the bottom mouse foot, making sure it goes under both the foot and its adhesive pad.
    • If the foot feels stuck, apply more heat and try again.
    • Gently slide the pick farther under the foot and lift until you can grip it with your fingers.
    • Use your fingers to peel up and remove the foot.
  3. Logitech G903 Mouse Feet Replacement, Clean off the old adhesive: step 3, image 1 of 3 Logitech G903 Mouse Feet Replacement, Clean off the old adhesive: step 3, image 2 of 3 Logitech G903 Mouse Feet Replacement, Clean off the old adhesive: step 3, image 3 of 3
    • If the rubber layer separated from its adhesive pad:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat it further.
    • Peel the adhesive off.
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry (about 1–2 minutes).
    • Remove the feet from their backing and firmly press them into place.
  4. Logitech G903 Mouse Feet Replacement, Remove the remaining mouse feet: step 4, image 1 of 3 Logitech G903 Mouse Feet Replacement, Remove the remaining mouse feet: step 4, image 2 of 3 Logitech G903 Mouse Feet Replacement, Remove the remaining mouse feet: step 4, image 3 of 3
    • Repeat the process to remove:
    • The top mouse foot
    • The two pentagonal mouse feet on the left and right side
    • The two small mouse feet in the center
Dominik Schnabelrauch
248,342 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 87
All Time: 3,761
