Logitech G910 Lights Replacement
  1. Logitech G910 Lights Replacement, Lights: step 1, image 1 of 1
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: step 2, image 1 of 1
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
  3. Logitech G910 Lights Replacement: step 3, image 1 of 1
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
  4. Logitech G910 Lights Replacement, Lift the film: step 4, image 1 of 2 Logitech G910 Lights Replacement, Lift the film: step 4, image 2 of 2
    • Gently lift up the plastic film in the top right corner.
5 other people completed this guide.
4 Guide Comments
So what do I do after I take apart my keyboard?
CuddlyZebesian - Reply
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire -
This is just a guide to open the keyboard, not a light replacement. Finish or rename the guide.
Wesley Mason - Reply
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 60
All Time: 7,678
