Logitech G915 TKL Feet Replacement
  1. Logitech G915 TKL Feet Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 3 Logitech G915 TKL Feet Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 3 Logitech G915 TKL Feet Replacement, Prepare your keyboard for disassembly: step 1, image 3 of 3
    • Slide the power switch on the top edge of the keyboard to the OFF (left) position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from the keyboard.
    • Lay the keyboard down with the feet facing up on a clean work surface.
    • If your work surface might scratch the keyboard, place a soft towel under it.
  2. Logitech G915 TKL Feet Replacement, Remove the feet: step 2, image 1 of 2 Logitech G915 TKL Feet Replacement, Remove the feet: step 2, image 2 of 2
    • Heat an iOpener and lay it on one of the feet for one minute.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic body.
  3. Logitech G915 TKL Feet Replacement: step 3, image 1 of 3 Logitech G915 TKL Feet Replacement: step 3, image 2 of 3 Logitech G915 TKL Feet Replacement: step 3, image 3 of 3
    • Insert the point of a spudger under an end of the foot.
    • Push the spudger underneath the foot and lift until you can grip it with your fingers.
    • The foot should come up without much force. If it feels stuck, apply more heat and try again.
    • Peel the foot up and remove it.
    • Repeat the previous two steps to remove the remaining feet.
  4. Logitech G915 TKL Feet Replacement, Reassembly information: step 4, image 1 of 2 Logitech G915 TKL Feet Replacement, Reassembly information: step 4, image 2 of 2
    • To install a new foot:
    • Use the flat end of a spudger to scrape up and remove any chunks of adhesive from the foot recesses.
    • Remove the new feet from their backing and firmly press them into place.
Spencer Day
164,859 Reputation
1,043 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,277 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 59
All Time: 711
