Logitech Gamepad F310 Disassembly
  1. Logitech Gamepad F310 Disassembly, Case: step 1, image 1 of 2 Logitech Gamepad F310 Disassembly, Case: step 1, image 2 of 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
  2. Logitech Gamepad F310 Disassembly: step 2, image 1 of 2 Logitech Gamepad F310 Disassembly: step 2, image 2 of 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
  3. Logitech Gamepad F310 Disassembly: step 3, image 1 of 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 38
All Time: 1,078
