Logitech Harmony Companion Button Pad Replacement
  1. Logitech Harmony Companion Button Pad Replacement, Remote Battery: step 1, image 1 of 1
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Button Pad Replacement: step 2, image 1 of 1
    • Push the battery cover upward.
  3. Logitech Harmony Companion Button Pad Replacement: step 3, image 1 of 3 Logitech Harmony Companion Button Pad Replacement: step 3, image 2 of 3 Logitech Harmony Companion Button Pad Replacement: step 3, image 3 of 3
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: step 4, image 1 of 2 Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: step 4, image 2 of 2
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Button Pad Replacement: step 5, image 1 of 2 Logitech Harmony Companion Button Pad Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Button Pad Replacement: step 6, image 1 of 2 Logitech Harmony Companion Button Pad Replacement: step 6, image 2 of 2
    • Use the plastic opening tool to remove the motherboard.
  7. Logitech Harmony Companion Button Pad Replacement, Button Pad: step 7, image 1 of 3 Logitech Harmony Companion Button Pad Replacement, Button Pad: step 7, image 2 of 3 Logitech Harmony Companion Button Pad Replacement, Button Pad: step 7, image 3 of 3
    • Lift the button pad up to remove it from the remote.
3 other people completed this guide.
Cassidy Wardlow
689 Reputation
4 Guides authored
USF Tampa, Team S1-G3, Nance Fall 2017 Member of USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Members
4 Guides authored
4 Comments
Ou pouvons nous commander «  Logitech Harmony Companion Button Pad Replacement »
Roger Tardif - Reply
Where can I purchase the button pad?
elijah - Reply
Also looking to find where to purchase. I called Logitech and they were clueless. My 4 year old was better equipped to respond.
Joshua Fuller - Reply
Thanks for posting these helpful steps. My harmony Companion was frustrating us because we had to press buttons really hard.
Cy Beaux - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 34
All Time: 3,021
