Logitech Harmony Companion Harmony Hub Motherboard Replacement
  1. Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: step 1, image 1 of 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: step 1, image 2 of 2
    • Remove the non-slip rubber pads on the bottom of the Harmony Hub.
  2. Logitech Harmony Companion Harmony Hub Motherboard Replacement: step 2, image 1 of 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: step 2, image 2 of 2
    • Unscrew the four 6.0 mm Phillips #0 screws.
  3. Logitech Harmony Companion Harmony Hub Motherboard Replacement: step 3, image 1 of 1
    • Insert the metal opening tool in the slit by the sensor.
    • Carefully separate the Harmony Hub cover from the base.
    • The metal opening tool could damage the device, so use with care.
  4. Logitech Harmony Companion Harmony Hub Motherboard Replacement: step 4, image 1 of 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: step 4, image 2 of 2
    • Unscrew the 2.0 mm Phillips #0 at the bottom right of the motherboard.
    • Unscrew the 4.0 mm Phillips #0 at the top left of the motherboard.
  5. Logitech Harmony Companion Harmony Hub Motherboard Replacement: step 5, image 1 of 3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: step 5, image 2 of 3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: step 5, image 3 of 3
    • Face the Harmony Hub base so the sensor is facing out.
    • Insert the plastic opening tool behind the motherboard on the gold section, which is to the right of the sensor.
    • Lift until you hear a click.
Cassidy Wardlow
689 Reputation
4 Guides authored
USF Tampa, Team S1-G3, Nance Fall 2017 Member of USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 513
