Logitech Harmony Smart Control Battery Contact Replacement
  1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: step 1, image 1 of 2 Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: step 1, image 2 of 2
    • Use both thumbs to slide the grooved cover off of the remote
    • Once the cover is off, remove the battery.
  2. Logitech Harmony Smart Control Battery Contact  Replacement: step 2, image 1 of 2 Logitech Harmony Smart Control Battery Contact  Replacement: step 2, image 2 of 2
    • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
  3. Logitech Harmony Smart Control Battery Contact  Replacement: step 3, image 1 of 3 Logitech Harmony Smart Control Battery Contact  Replacement: step 3, image 2 of 3 Logitech Harmony Smart Control Battery Contact  Replacement: step 3, image 3 of 3
    • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
  4. Logitech Harmony Smart Control Battery Contact  Replacement: step 4, image 1 of 2 Logitech Harmony Smart Control Battery Contact  Replacement: step 4, image 2 of 2
    • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
    • Slide the circuit board out from the housing .
  5. Logitech Harmony Smart Control Battery Contact  Replacement: step 5, image 1 of 1
    • Locate the battery contacts on the circuit board.
    • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
Josh Hendricks
464 Reputation
4 Guides authored
IUPUI, Team 3-2, Harley Fall 2015 Member of IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Members
5 Guides authored
1 Guide Comment
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 18
All Time: 5,150
