Logitech Harmony Smart Control Hub Light Bulb Replacement
  1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: step 1, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: step 1, image 2 of 2
    • Use a spudger to lift up one of the rubber pads on the bottom of the hub.
    • Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
    • Repeat for the second rubber pad.
  2. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 2, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 2, image 2 of 2
    • Use a PH00 screwdriver bit to remove the four 6mm Phillips screws on the bottom of the device.
  3. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 3, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 3, image 2 of 2
    • Use a spudger to separate the top and bottom pieces of the device.
  4. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 4, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 4, image 2 of 2
    • Use the PH00 screwdriver bit to unscrew the three 4mm Phillips screws on the control board.
  5. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 5, image 1 of 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 5, image 2 of 2
    • Place the end of the opening tool under the yellow corner of the circuit board as shown.
    • Gently push upward to pry the board from its housing.
  6. Logitech Harmony Smart Control Hub Light Bulb Replacement: step 6, image 1 of 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 6, image 2 of 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: step 6, image 3 of 3
    • Determine which of the five bulbs are defective.
    • Turn the board over to expose the bulb solder.
    • Using a soldering iron, remove the solder and bulb. Replace with a new bulb and re-solder.
2 other people completed this guide.
Josh Hendricks
464 Reputation
4 Guides authored
IUPUI, Team 3-2, Harley Fall 2015 Member of IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 36
All Time: 702
