Logitech Harmony Smart Control Remote Buttons Replacement
  1. Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: step 1, image 1 of 2 Logitech Harmony Smart Control Remote Buttons Replacement, Remote Buttons: step 1, image 2 of 2
    • With both thumbs, slide the grooved cover off the end of the remote.
    • Remove the battery once cover is removed.
  2. Logitech Harmony Smart Control Remote Buttons Replacement: step 2, image 1 of 2 Logitech Harmony Smart Control Remote Buttons Replacement: step 2, image 2 of 2
    • With the PH00 bit, remove both of the 4mm Phillip screws on the remote.
  3. Logitech Harmony Smart Control Remote Buttons Replacement: step 3, image 1 of 2 Logitech Harmony Smart Control Remote Buttons Replacement: step 3, image 2 of 2
    • Using a metal spudger, pry the remote. Maneuver around to separate both sides.
  4. Logitech Harmony Smart Control Remote Buttons Replacement: step 4, image 1 of 3 Logitech Harmony Smart Control Remote Buttons Replacement: step 4, image 2 of 3 Logitech Harmony Smart Control Remote Buttons Replacement: step 4, image 3 of 3
    • Manualy separate the two pieces of plastic.
    • Using the metal piece from the housing, pry up the circuit board. Do not disconnect anything.
    • When the circuit board is pried, slide the circuit board out of the housing.
  5. Logitech Harmony Smart Control Remote Buttons Replacement: step 5, image 1 of 1
    • From the front of the remote, remove the buttons. Clean or replace the necessary buttons.
2 other people completed this guide.
Josh Hendricks
464 Reputation
4 Guides authored
IUPUI, Team 3-2, Harley Fall 2015 Member of IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Members
5 Guides authored
9 Guide Comments
Excellent guide. However, I can’t find a supplier for the button pad. Any suggestions?
fhaist - Reply
Hi there,
My son dropped mine in water. I opened it and dried it off but it still doesn’t work.
I could give you my button pad if you want.
Benoit Lagarde -
Where do you purchase button replacements?
Steve Lutes - Reply
Flavio Campos - Reply
Excellent! I wasn’t sure if it was possible to crack it open or not. Thanks, I was able to clean it up.
John Wall - Reply
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 49
All Time: 6,222
